I've read everything I could find on this board and on TurboFord and there seems to be disagreement about the function of the cam belt tensioner. When I got my 88 TC a few months ago I discovered that the tensioner spring was installed backward on the pivot bolt. I dicided to "fix" it. I assumed, incorrectly it seems, that the tensioner should provide tension while the engine is running, so, after turning the spring around and (finally) getting it on the pegs I lossened the hold-down bolt in the slot and fired it up. The belt promptly skipped several teeth and the car won't run. So, after the fact, I read the Haynes manual and discovered that one is supposed to pry the tensioner into position and lock it down. If that's the case, what is the tensioner for? Some previous posts here also seem to suggest the the tensioner should be locked down, while others indicate the opposite. Please help this newby understand.
88 TC, MAF conversion, Gillis, Front mount IC, multiple oil leaks
