slacken00
Jun 2001
waynesboro pa
if the cam is going bad or is bad would my tc have a miss and would i get bad gas mileage, bc i have changed the pip, tps, egr, and had two people do compression tests and fuel pressure test and everything checked out ok and timing was 10
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
Glenn 88TC
Lebanon, PA
Did you run the codes? Was the fuel pressure checked while driving too? Does the car smoke black at all?
NO TC and NO headaches.
Keith Nubel
Liberty Township, OH
Yes, it could miss. Most likely poor idle and low on power. Did it start suddenly? Pull codes 1st. It should only take 1.5-2.0 hours to inspect the cam, but I'm guessing it's not the cam. It is possible to wipe a lobe and miss on 1 or 2 cylinders.
1985 TC
slacken00
Jun 2001
waynesboro pa
little smoke and yea the fuel pres. was checked when it was drivin, how do u check the cam, and it def. doesnt have the power it should bc this is my 5th or 6th tc and its very sluggish
Are you getting any top end noise. Ofter there will be a ticking or louder if the lobe(s) are seriously worn.
Have you checked cam timing, then ignition timing?
A cloggged cat will affect power and mileage. It may cause the exhaust manifold to glow brighter than normal under just easy driving
slacken00
Jun 2001
waynesboro pa
no noises, dont know what timing they checked and i dont think the manifold glows at all, but it stinks
slacken00
Jun 2001
waynesboro pa
oh yeah it doesnt run that bad when its cold either, once it warms up it starts the missing and stuff
THUNDERPINTO
Nov 2004
KENT ,NY, USA
Sounds like your O2 sensor is puking. If it's got lots of miles it should be changed anyway, as the paladium wears out it wont signal properly.
2 87 TC's one is a Watkins Glen
88 TC no engine or interior,a no rust project
66 mustang coupe,71 triumph spit
52 Dodge powerwagon(s)
79 TC powered Pinto
99 Harley Roadking
73 750 Norton Commando Combat
cnpowell
Nottingham, MD
When you say the timing was 10 degrees .... was it checked with the spout connector installed or out. I set mine to 12 degrees with the spout connector out.
Carl (cnpowell)
Glenn 88TC
Lebanon, PA
Does the car smoke black at all? Codes?
