Last time I had the bird running when it hit boost it blew tranny fluid out everywhere. I am guessing the boost blew the diaphram in the modulator and is causing this... sound right? Should there be a one way check valve in the vac line going to the C3 trans to keep pressure off the modulator under boost? Also is it supposed to plug in on the upper intake vac tree?
Installing a new fuel pump this morning hope it runs!
Thanks,
Thanks,
Mike
"Do to others what you would have them do to you" Matthew 7:12
1985 Turbo Coupe, Stock for now...
1995 Lightning
1966 Mustang
1965 Prostreet Mustang
1969 Bronco
1995 Lightning
1966 Mustang
1969 Bronco
