Wags88TC
Las Vegas
So I had a leaking injector so I changed 'em all(just stock brown tops for now). I removed the upper intake to ease the installation - everything went back together good except over about 8-10 lbs of boost the intercooler blows off! I cranked down the clamps, now after a few squirts through the gears it still manages to pop the IC out of the TB hose! never had this problem till I did the injectors. I've been thinkin' about a Bypass or BOV anyway, so what's everybody using?
Steve Wagner
Nato member
84 SVO
Do you have the bracket that bolts the IC to the exhaust manifold stud on, and is it tight? That bracket does quite a bit to hold the IC in place. Last year, I forgot to tighten down the nut that secures the bracket to the stud, and blew hoses off a few times at 20 psi boost until i found the nut loose. Also, be sure there isnt any oil film inside the hose or on the outside of the IC or TB where the hose fits on.
I am just running the plastic Bosch bypass valve that most here and over at TF are running. Got mine from Performance Techniques when I got my new turbo from them last year. It cost about $40, but that was before I found out there are other sources for about $25 new.
A bypass or blowoff valve won't cure that problem. Did you reconnect the intercooler support bracket?
Wags88TC
Las Vegas
I could've blown off a couple of punks in a RS camaro today - but the IC blew off between 1st and 2nd(not much of a race when it just whooshes after about 5 lbs of boost) So I got under the hood shoved it back on and tightened it down and realized the only thing different was leaving off the bracket! I listened to a guy that told me it transfers a lot of heat to the IC! True, but if it won't stay on it doesn't do any good!!! I've still got the bracket, but I'm gonna start on the front mount IC pretty quick.
Steve Wagner
Nato member
84 SVO
Mr. Sam Ford
Richmond, VA
no, put the bracket back on! You really need it, or so I've found. Never heard it transfers heat, I think the IC in its stock location is beyond help anyway [Image: smile.gif]
'88 Thunderbird TC
ATR 3" cat back, Sac. Mustang 3" DP, Tiny Avenger boost controller, K&N cone in fenderwell, Walbro 255 lph fuel pump, Perf. Techniques T03/T04E turbo, KB Trac Kit
'86 Mustang GT
usual bolt on stuff
'88 Thunderbird TC, daily headache with a few mods, 14.65 and still not happy
Hybridbird
Aug 2001
Rockford IL
Hey Jeff K,about the valve you have,does it earn it's keep,as far as you are concerned?I mean is it worth it?$40 bucks(or $25 for that matter)doesn't sound like too serious of an investment,does it really do it's job?
weird, on my old thunderbird i only had one of the bolts haphazardly bolted in and it never gave me any problems....i cant imagine the IC "blowing off" !!!
about the blow off valve....as far as fuel economy and driveability around town goes, is it better to have it or to not have it?
Dan E
Greensboro, NC
A Blow Off Valve (vents to atmosphere) or Bypass Valve (vents back in front of the turbo) is used to keep the air charge from slamming back into the spinning turbo when you lift (close the throttle's butterfly valve) in between shifts. It prevents damage to your turbo and keeps the turbo spooled up between shifts. Perhaps the latter fact would improve gas economy, but that's not the main purpose.
Dan Eaves
[This message has been edited by Dan E (edited 09-12-2001).]
Dan Eaves
well if anything i thought having the turbo constantly spooled would use MORE gas...
GaryS#2
May 2001
B.C. Canada
[QUOTE]Originally posted by sean:
[B]
I think "spooled" and "spinning" are two separate things.
Spooled up is when it's under boost.
Spinning is just that.
If you slow the turbo down when shifting , you have to use more effort to get it going again.Therefore using more gas to get things going again.
Thats my theory anyway.
Grocery Getter/Rice Cooker.
