Wags88TC
Las Vegas
I finally put the BP valve(had the parts for 6 months)on the car. I don't know if it's any faster - but it sure is more "driveable". After I did the clutch(lightened the flywheel at the same time)the car seemed to be more "jerky" when shifting, that has gone away now!
Steve Wagner
Nato member
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR,Bypass valve, 3" exhaust from turbo to tip (high flow cat/ Dynomax Superflo muffler), A-pillar gauges(A/F & Boost), 16" Prime 5 spoke wheels(245/45ZR16 Bridgestones). Workin' on the front mount IC and some exterior mods
Steve Wagner
Nato member
84 SVO
what's a by-pass valve?
1988 TC 5 spd. Chip, Gillis Valve, K&N.
garycono
Aug 2001
Burke, Va. USA
I agree...I put a Bypass Valve on mine a few months ago and have really noticed a difference in the "driveability"....more interesting though is there is less engine noise at all throttle positions.
88TC, 5 speed, 2.5" ATR exhaust, K&N, Cold Air Intake, Ported and Gutted Upper, Ported Lower, Ported E6, calibrated injectors, coolant filter,Aftermarket electric fan, Spearco Front Mount Intercooler.
Modified leather interior from a 2001 Monte Carlo, lowered 1" using H and R sport springs.Modified ram air plenum.Bosch By-pass valve.
88TC, 5 speed, 2.5" ATR exhaust, K&N, Cold Air Intake, Ported and Gutted Upper, Ported Lower, Ported E6, calibrated injectors, coolant filter, Aftermarket electric fan, Spearco Front Mount Intercooler.Modified leather interior from a 2001 Monte Carlo, lowered 1" using H and R sport springs.Modified ram air plenum.Bosch By-pass valve, MSD 6AL and Blaster coil ignition.
See this thread: http://natoubb.turboford.org/Forum1/HTML/000648.html
and http://natoubb.turboford.org/Forum1/HTML/001237.html
and http://natoubb.turboford.org/Forum1/HTML/002093.html
Yup, every turbo car needs a BPV. THe drivability difference is amazing.
makes that much of a difference eh? man, now i have to get one. the set up from tiny avenger looks nice and neat. i'll go with that unless someone has a better idea. pete d, thanks for the links. very helpful.
[This message has been edited by flyguy (edited 04-19-2002).]
Flyguy... The TA kit uses a Bosch BPV that costs maybe $30 new, or can be found in turbo Volvos, Saabs, etc at the JY almost for free. Just fab up your own system to tap a 1" dia hose into the IC or the TB, and a 1" dia hose into the VAM to turbo hose, and you will be all set for MUCH less $$ than the TA kit.
ok, thanks jeff. 00 Windstar (wifes vehicle)? wasn't that you i saw driving the mini-van around tiefenthaler park? [Image: biggrin.gif]
Nate K
Eastern Shore of Virginia
flyguy.... alot of us use the Ric Gillis Bypass Valve $39.00. Excellant quality, easy to adjust, easy to disassemble and clean, easy to upgrade spring for larger turbos, and best of all Ric is a great guy to deal with, stands behind his products 150%.
http://www.boostvalve.com/
http://www.boostvalve.com/pricelist.html
http://www.boostvalve.com/new.html replacement/new parts
[This message has been edited by Nate K (edited 04-19-2002).]
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
yeah, i have that already and it's great. maybe i've been hitting the crack pipe too much today but i'm fairly sure from everything i've been reading that the by-pass valve is different.
