Burn off 3yr old gas or Drain it?
ridgeback Offline
so the Bird runs again after sitting for 3 yrs. Gas is stank and old but does fire up the engine. I have not taken it on the road for a stress test just yet... gotta button up some lose ends 1st.
So should I burn off the 3/4 tank of old gas that has been stabilized a few times, or should I drain it?
Not sure how to dispose of it once drained tho.
Ron
Ron
Black 87 TC, 2nd owner since 1990@21k, now@109k.
Current Mods: Gillis valve @18psi. K&N Cone. Removed AC components, New: Esslinger Aux. Shaft, Seals, Melling Oil Pump, Heater core. Ranger cam & rollers, new tower bearings, Walbro 255 fuel pump
margood Offline
However you decide to ultimately dispose of it, definitely drain it first.
87 TC Not bone stock anymore, no rust, sittin' pretty, always trying to get it running...
If it has had fuel stabilizer added, I would still drain all or most of it, and use the drained gas in lawn equipment, etc.
jmthunderbirdturbo Offline
top it off with C116 and let it ride.
ridgeback Offline
C116 ??? I looked it up on google and got "Commodore 116" lol.
I assume its some kind of Octane additive? And easily available?
I am thinking of draining most of it. Shut I let the fuel pump do all the work by disconnecting the return fuel line just below the oil filter area, or is there an easier way?
Ron
disconnect it just in front of the tank, where it connects to the fuel filter near the rear Pass tire.
BJL Offline
Moderator
i ran some 15yr old gas a few years back... i ended up adding a lot of new gas and it was fine.
Brian Larkin
88TC 330,000 miles
Slightly Modified
ridgeback Offline
15 yrs! wow didn't know gas could last that long.
I think I may dump about 5 gal. to get the tank half empty then top it off with some fresh Hi Octane.
I have a new fuel filter which I will replace once this tank runs empty.
Thanks guys!
Ron
C116 is basically aviation fuel.
-J0N
