ridgeback
Feb 2002
Milford,CT
so the Bird runs again after sitting for 3 yrs. Gas is stank and old but does fire up the engine. I have not taken it on the road for a stress test just yet... gotta button up some lose ends 1st.
So should I burn off the 3/4 tank of old gas that has been stabilized a few times, or should I drain it?
Not sure how to dispose of it once drained tho.
Ron
Ron
Black 87 TC, 2nd owner since [email protected], [email protected]
margood
Apr 2014
Casa Grande, Arizona
However you decide to ultimately dispose of it, definitely drain it first.
87 TC Not bone stock anymore, no rust, sittin' pretty, always trying to get it running...
If it has had fuel stabilizer added, I would still drain all or most of it, and use the drained gas in lawn equipment, etc.
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
top it off with C116 and let it ride.
ridgeback
Feb 2002
Milford,CT
C116 ??? I looked it up on google and got "Commodore 116" lol.
I assume its some kind of Octane additive? And easily available?
I am thinking of draining most of it. Shut I let the fuel pump do all the work by disconnecting the return fuel line just below the oil filter area, or is there an easier way?
Ron
disconnect it just in front of the tank, where it connects to the fuel filter near the rear Pass tire.
BJL
Williamstown, New Jersey
i ran some 15yr old gas a few years back... i ended up adding a lot of new gas and it was fine.
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
ridgeback
Feb 2002
Milford,CT
06-17-2016, 02:36 PM
(This post was last modified: 06-17-2016, 02:37 PM by ridgeback.)
15 yrs! wow didn't know gas could last that long.
I think I may dump about 5 gal. to get the tank half empty then top it off with some fresh Hi Octane.
I have a new fuel filter which I will replace once this tank runs empty.
Thanks guys!
Ron
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
C116 is basically aviation fuel.
-J0N
