87turbotbirdmatt
Mar 2005
Sarasota, Florida USA
I accidentaly broke the plastic cover covering the "gear" at the front of the engine compartment. It looks so ugly now! I saw on some of the nicer TC's a "billet look" or chrome gear to replace this, is it involved to replace this gear? And also where can I get one?
_ _ ___________ _ _
87TC: K&N,
Bullet Exhaust - Gillis Valve, IHI @18PSI
Qwertys
Mar 2004
California
you lost me, gear? you mean timing belt cover?
'85 TC BPV and Ford FMIC
87turbotbirdmatt
Mar 2005
yes, that's it. Timing belt cover.
_ _ ___________ _ _
87TC: K&N,
TurboCoupe50
Chesapeake, Va
Back in the '70s the timing covers were metal on the 2.3s. If you can find one, it could be chrome plated.
Three 1988 Turbo Coupes .....
And now a 1987
Gary S
Burlington, KY
The plastic cover is still available from Ford. It's Part Number E3ZZ-6019-A (Cover Assembly). The last one I bought cost me $48.15. The earlier ones were metal but the timing mark set up was different (the degree markings were on the pulley rather than the cover). All the cover had was the pointer. You would have to swap the plastic piece off the plastic cover to the metal one and then hope that you got it in the right position.
Gary
87turbotbirdmatt
Mar 2005
Thanks y'all are a great bunch! All help greatly appreciated. The "gear I was talking about is the top big gear that the timing belt goes on. Any fancy gears available too?
___________________
87TC: K&N, Bullet Exhaust - IHI @17PSI
_ _ ___________ _ _
87TC: K&N,
There are various "adjustable" cam gears that allow advancing/retarding the cam timing. One of the most popular for our engines is made by Race Engineering: http://www.raceeng.com/Pages/Page_17_4cyl.html
NATO Member. It's not a vice, it's an obsession
Bumper Sticker of the Year."If you can read this, thank a Teacher... and since it's in English, thank a Soldier.
Never be afraid to try something new, remember amateurs built the ark, professionals built the Titanic.
Politicians and diapers should be change often, and for the same reason.
88 TC, 86 SVO, 04 Escape. Mods list at
karnage
Mar 2003
Olympia, WA.
What I did was used the plastic cover and cut out the middle where the gear is so I can adjust my cam gear.I have a racer walsh adjustable cam gear.
rocky11
Jul 2002
cherry hill nj
is the cover really important in terms of protecting the timing belt?. mine broke so im just using the very bottom of it,just for setting thr timing.plus if you have an essy adjustable cam pulley or one like it and your motor is pretty clean imo it looks kinda neat.
86 t/c
