In going through again and testing all my hoses, I found the ones on the BCS weren't holding vacuum; they drained slowly.
So wouldn't you guess that I BROKE the port off the BCS trying to remove the hose to replace it.
I've planned on buying a gillis valve anyway, but in the mean time what can I do with this in order to still drive/run it safely? I've read fishtank valves are a mixed bag. At the very minimum, I want to be able to run it in neutral to diagnose my rough idle while waiting for the gillis.
Also, I found that the hose that T's into the vac tree/intercooler hose - the one that goes into the fender well (tree labeled s/c, speed control?) also does not hold a vacuum.
Should the speed control hold a vacuum?
This is the green hose from the diagram, that leaves the page-right. Without this hose, the entire line holds vacuum; even without the IC end being plugged. I can't blow through it either; must be a 2 way check valve?
Thanks!
Thanks!
Sold it *
