breather cap on top of the valve cover
Keith Pellerito Offline
Had a question in regards to the breather cap on the backside of the valve cover. It has a metal hose that runs down to the turbo, my question is do we really need to have the two attached? I would like to delete it if I could and put a nice looking regular breather up there without the metal bent steel line, can I delete it? Or am I stuck with it? Sorry about the wording, I have been inhaling gumout cleaning out my engine compartment.
thanks
yeah it is fast, just a little slow getting back to the garage!🚓
Joe F Offline
I think that's part of the "emission system". Hopefully someone with more knowledge withh chime in. Sorry not to have been more help.
Be Cool,
Joe
JR's Place - My 87 TC
Qwertys Offline
that hose reclaims lost fuel vapor and reintroduces it into the intake.
from what i remember...
'85 TC BPV and Ford FMIC
Keith Nubel Offline
I believe Forced4 sells a breather to replace the stock breather. Most of the emmission controls on these cars have very little effect on the performance. A high flow cat and exhaust can help a lot. Personally I would just leave the breather alone.
85.5 TC 5 speed, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount Motorsport intercooler & sport grille, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,Motorsport 140 mph speedometer,Motorsport lowering springs, Kenwood EZ500 200 watt receiver with Cerwin Vega speakers sound system, air conditioning converted to R134A and Sanden compressor retrofit kit installed, under restoration
1985 TC
That metal / rubber hose sucks in filtered air to replace the air removed from the crank case by the PCV system when intake is under vacuum. Under boost, this hose vents blowby and boost that leaks past the intake valve and their guides to the intake to "reburn" them.
Jeff and all the rest thanks for responding, so does that mean that I have to keep the metal rubber hose therir so it runs more effecient, emmissions tests are not a point with the car, I am modding it and as far as I can remember, my metal hose had a kink in it for the longest time, I broke it when I was pulling the motor out because of the kink so I am at the point where I either get a new hose or leave it, if I can leave it, I would like to do that, I just want to make sure that it is not going to affect performance. And also, the little black hose that goes to the charcoal box, it goes through the wheelwell and goes into the firewall that way, where exactly does that connect to and is that box important?
You can just put a breather on the VC, but it may end up blowing some oil out on the VC, and making a mess. If you want to keep the system stock, you could fab up a new metal line (I dont see why copper tubing couldnt be used), or get some high temp silicone hose, and do it all with the hose, being careful to tie the hose up so it isnt too close to the turbo and exh. man.
THANK YOU!!!!
