brakes,relays, pump........problem
repoman88tc Offline
okay, i lost brakes recently all lights lit up on 88 tc. pulled dual relay box down, tapped relays, then pump kicked on again. replaced relays/both(not sure which one powers brake pump), put relays back in firewall mounted box and brakes stopped working and lights lit up on dash again. if i take the firewall plastic box down that holds the relays and let the relays hang loose the darn brakes always work and give no problem. but if i put them back in the box and mount it , i loose brake accumulater pump power and then brakes. any suggestions????
alan brown/statesboro,ga
86 9L svo
88 tc 5 speed blue
88 tc auto black
[email protected]
86 9L AND 2R SVO`s(sold)
88 tc 5 speed black/loaded/Injen/Gillis
97 sho V-8 taurus/black loaded
96 sho v-8 taurus/red loaded
[email protected]
Noname
Guest
Perhaps you should check the connections again? It sounds to me like they are getting knocked loose, but what do I know? hehe, I've never dealt with brake crap, but first guess is its loose again.
Hope this helps,
Ryan
Joe F Offline
Almost assuredly a connection problem - make sure to check the harness connection at the relay very well.
Be Cool,
Joe
JR's Place - My 87 TC
The wires to the relay sockets tend to get hot and melt off their insulation, causing all kinds of problems. Could also be a bad crimp connection where the wires crimp to the metal pins in the relay sockets.
repoman88tc Offline
thanks all for your input, i`ll thoroughly inspect those connections and post what i find. but hey, if all else fails, i could leave the relays dangling under the hood and have brakes. thanks
86 9L svo
88 tc 5 speed blue
88 tc auto black
[email protected]
[email protected]
