Brakes???
Harvs Offline
I've been trying to fix my ABS for the longest time. Where could I get the codes ran? I might just change them to just four wheel disc, no abs, how would I do this?
I sent you some info in an e-mail
Correction, I tried to send you an e-mail, it bounced back. If you want the info, e-mail me
BROTHER-Rebel-OUTLAW Offline
Keep the ABS pump, just disconnect the fuse for the system. Then it defaults back to normal power brakes.
I say keep the pump, because it's a built in brake bleeding system if you ever need it, and if you ever wanted to go back to stock [Image: rolleyes.gif] you'd have no work to do [Image: biggrin.gif] !
Keep the shiny side up and I'll see you in the fastlane!
->JP
"I didn't think it was possible,
but this thing both sucks and blows at the same time" -Bart Simpson
BROTHERRebelOUTLAW
Harvs Offline
Hey Pete, i did not get an email address, I was always going to do mine. I always used my dads, I'll make a new one and give it to you by tommorrow
Harvs Offline
Here is my e-mail address [email protected]
[This message has been edited by Harvs (edited 12-29-2002).]
Harvs Offline
Where is the fuse for the ABS.
The pump relay and the main power relay are under the black plastic cover directly below the vacuum tree on the firewall.
