Brakes
shiloh66 Offline
I have just converted my 88 to 5 lug using sn 95 parts. I now need to bleed my rear brakes , but my abs in inoperable.  Can I still bleed them without working abs ?
88 T/C , 5 speed,white
Chas K 88 Offline
I don't think your ABS being inoperable will prevent you from bleeding them. My ABS doesn't work either (reason in my sig) but I can bleed my brakes and they work fine.
Chas K
shiloh66 Offline
My abs worked before I did the five lug. I have only disconnected the wheel sensors. But was afraid the abs pump wouldn't work since the sensors were unhooked. The car is still on jack stands, as I haven't had time to even try bleeding them. Thank you for your response
Mikey97D Offline
(03-23-2023, 01:57 AM)shiloh66 Wrote: My abs worked before I did the five lug. I have only disconnected the wheel sensors. But was afraid the abs pump wouldn't work since the sensors were unhooked. The car is still on jack stands, as I haven't had time to even try bleeding them. Thank you for your response
Assuming the pump still works so it should be pretty effortless to bleed the rear brakes.
fred k Offline
Get a handheld vacuum pump at Harbor Freight ($25) and connect it to the bleeder screw on the calipers.  Pull fluid until there are no bubbles.
https://www.harborfreight.com/brake-blee...63391.html
fred l kennedy
spittinfire Offline
You'll be able to bleed them just like normal, the ABS not working won't affect that process at all. I did the same 5 lug swap and no problems.
An interesting bit of information on ABS, the SN95 ABS system is completely stand alone needing only power and signals from the sensors. I plan to convert my car to vacuum and I'm going to try to work the SN95 ABS into the system since all my brakes are now SN95.
shiloh66 Offline
Thanks for all the replies !
Mikey97D Offline
If the pump works on a '87-88 TC, you don't need a vacuum pump for the rear brakes.  Turn the ignition on, have someone hold the pedal down and open the valve.  It pumps itself.
Front brakes you can use the vacuum pump on.
Please do a search in the FAQ section here.  There's great procedures for most everything on the car.
Edit: Found the thread! https://turbotbird.com/thread-bleeding-r...kes--31356
shiloh66 Offline
Thank you
