et's88tc
May 2006
charlotte, nc
have tried bleeding brakes front bleed fine, trying to bleed rears per forum and ford service book no fluid comming out bleeder screw. what gives any help would be nice.
1988 tc, The 5spd is in with minor stuff left.
It's known that the lines can get plugged. Might check for that
et's88tc
May 2006
charlotte, nc
do i need to check at the spliter block or further up. the abs and brake lights on dash ar still on.
Is the hyd. pump running when it should? Usually, if both brake and ABS lights are on, it is a sign of extremely low pressure in the accumulator, usually caused by an inop pump. Inop pump can be caused by many things, such as bad pump relay, bad ignition switch, bad pressure switch, or bad pump motor.
et's88tc
May 2006
charlotte, nc
will check tomorrow, thanks for the help. trying to get it up and running by time charelston next month.
et's88tc
May 2006
charlotte, nc
i checked pump motor it's fine, i'm not getting any continuty between motor relay and motor harness, it says service circuits 538a and 538b what are those and does any one have a diagram of these circuits. i only have the ford chassis and electrical manual b1. so any help would be appriciated.
et's88tc
May 2006
charlotte, nc
help,i'm lost
DonH
Jun 2002
Central Massachusetts, USA
538 is the gray/red wire from the pump motor relay to the pump. It is spliced with another gray/red wire in the harness to become two gray/red wires wires, 538a and 538b which exit the harness to go to the pump motor. Did you confirm that the pump runs? If it runs 538 is working as it is the power to the pump. The two gray wires from the pump are spliced to other gray wires (circuit 430) that are grounded to the body. You should have continuity with ground on the two gray wires.
1987 TC stock except ATR 2.5"
et's88tc
May 2006
charlotte, nc
yes don i checked the pumpmotor and it does run.but not getting continuity from either of those lines, i checked pump motor by useing a separte power line i made up to use from battery.
Sluggo
May 2004
Huntingtown, MD., USA
Brake Booster Relay Diagnosis - by Jeff Korn
Find this in the FAQ's. It should help.
Doug
