Brakes
Sauced1173 Offline
Ok, so I drove this car home the other day and the brakes felt fine until i was around the corner from home. The pedal was real hard and it felt like there was no stopping. Does anyone know what this means? Thanks
'88 Turbo Coupe
5sp M.T.
Needs some TLC
xcrunnerbd Offline
Did the brake light turn on? Any leaks or air in the system?
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
Sauced1173 Offline
no brake light did not turn on, and what air system are you referring to? like the vacuum system? there are none that i am aware of, its weird because on a 20 mile trip, they didnt start acting up until the end. and since shutting the car down and firing it back up, they seem to work fine again.
'88 Turbo Coupe
5sp M.T.
Needs some TLC
zbird Offline
Sounds like your accumulator lost pressure giving you a hard pedal. It is part of the ABS Master cylinder and is on the driver side next to the fender attached to the master cylinder.
Dom Z
99 F150 4x4
14 Ford Escape 2.0L Turbo
Sauced1173 Offline
what does this accumulator look like?
'88 Turbo Coupe
5sp M.T.
Needs some TLC
zbird Offline
It is black Round and has a white sticker with red letters. it is attached to the master cylinder.
Dom Z
99 F150 4x4
Bill S. Offline
Its on the drivers side, kinda tucked in there.
From the picture of Dan Eaves's TC on the tech articles page:
http://natomessageboard.com/uploads/00005340/brake.jpg
'88 TC T5
'85 XR7 Roller
Mods on hold pending swap.
Stinger header & mBC on shelf
xcrunnerbd Offline
I wasn't referring to an air system or vacuum. I was asking if you had any air IN your system meaning brake system. Air bubbles can make strange things happen depending on where they are.
Sauced1173 Offline
yeah i understand what you mean, it has been my experience to get a squishy feeling when there is actually air in the fluid system. i appreciate all the helpful tips, i hope to get this all taken care of real soon. i will keep things updated as i go.
i do recall seeing the accumulator tucked in there now. i am not familiar with this type of set up. i will be digging into it this week more, is there a good way to check these or is it something visual or just change it and see what happens?
thanks again.
'88 Turbo Coupe
5sp M.T.
Needs some TLC
terr5178 Offline
there is a relay that turns the power on the accumulator pump. Mine was corroded and would work fine sometimes and other times would stop working and Id get the hard pedal you described. I replaced the $10 relay and never had a problem again.. its called the antiskid relay and is located under the hood near the accumulator.. good luck
