Brake upgrade
cinnamonrollz Offline
My TC has a small block chevy swapped in, makes more power than it needs. When doing a burnout, my front brakes can't hold my car still. Due to my wheels a 5 lug swap is out of the question. Would some aggressive pads and stainless caliper sleeves be able to hold it still? I've heard a couple different brake setups one can run however all of them involve using a custom proportioning valve. I don't want to touch the prop valve or rear brakes at all. I also don't think a line lock would be enough. Any input is appreciated. Thanks.
23027 Offline
Personally, I think a Line Lock would work well for you.. 100% of your braking power on your front wheels, with no resistance at the rears for the burnout. I would think even if for some reason this didn't work, it is a much cheaper option than the upgrading brake options
87 Turbo Coupe
New Heart & Lungs as of 245,225km.
302 H.O Swapped.. Bolt ons.. Tremec 3550.. 4.10's.. 18's..
https://postimg.org/image/efv6lnn35/
boboli Offline
You don't say what year TC you have, but I'd 2nd a line lock.
