Brake Reservoir
dezridin2 Offline
The line coming from the reservoir to the pump motor is leaking at the reservoir.What is the best way to seperate the reservoir from the master cylinder?
I believe there is one screw that hold it in place. Kind of underneath twoard the front. I think everything else is slip fit and the resevoir lifts up
Yup... one screw. It sticks out horizontally toward the pass side about 2" behind the valve body, and in line with the top of the valve body.
