Brake line
gadgetolds Offline
Just found out my brake line that runs along the axle is leaking really bad, looks like right in the middle and I think it happened when I got it stuck yesterday. Is there an easy fix for this?
Sounds like you need to replace it.
russ c Offline
Replace it is the only proper fix. It will also be the easiest in the long run.
86TC Saved from certain death
88TC Gave its life so other TCs could live.
88TC DD.
gadgetolds Offline
Ok, does anyone know how much line ill need? any "tips"?
turbo tom Offline
When replacing mine,the line was rusted so bad it broke off at the flare fitting.I had to get adapters to fit the correct line to the t-fitting. The T-fitting is 1 size larger than the fitting at the caliper. Hopefully you'll be able to reuse the larger fitting on the new pipe.
Speak softly and carry a ...errr really big turbo. 84 GT R.I.P 94 F250 Turbo Diesel
gadgetolds Offline
Ok thanks for the tip, now I have a question on the line, from what i can see it looks like one solid line from one caliper to the other? And the nuts on the calipers are sorta kinda stripped. Someone told me that it cant be a solid line? Any ideas?
There is a flex line that runs from the frame to a junction block on the front driver side of the pumpkin. 2 hard lines come from the block, one toward each caliper. Near each caliper, the hard line converts to a roughly 6" long flex hose that goes to the caliper.
gadgetolds Offline
Ok Jeff, im confused then, what is the line that I have running on the rear side of the axle? it goes from one caliper straight over to the other?
I need to just sell this fkin thing, im getting so frustrated!!
http://natomessageboard.com/uploads/0000...Lines2.JPG
gadgetolds Offline
Thx Pete, that helps ALOT..
