(This post was last modified: 09-24-2020, 12:53 PM by Mikey97D. Edit Reason: unwanted font edit )
Last Sunday I discovered my brake lights were not working by almost getting rear ended.
First thing I did was do a search here at NATO and read by either one of the Brian(s) or Jeff that the wire breaks fairly regularly (Thanks Guys!). Also, I would agree that getting under the dash would be easier if you take out the driver's seat, but I didn't do that instead cried and moaned as I contorted getting under the dash.
When I peeked under the dash it wasn't obvious that any wires were broken. I gently pulled and tugged on each lead but everything looked good. Mine you I wear bifocals at this point in the game, but we'll come back to this.
Autozone had the light switch and the plug in stock for me. My first trip I just got the switch that didn't fix my problem. My 4 way flashers worked and I had power across the fuse (15 AMP location #1) with the flashers on. I checked the continuity to the switch on both leads and found none.
With my glasses off I saw the insultation was still attached, but the wire was broken on the opposite side of the plug terminals. I've attached a picture to hopefully help someone else. Might not happen again for anyone else but just maybe.
Here's a link to the part at Autozone: https://www.autozone.com/electrical-and-...v-JRuDo__0
Duralast Stoplight Switch 674
And I have brake lights again!!!
