Trickie67
Oct 2005
New Mexico
I have a 1988 TB Turbo Coupe.
I have problem with rear brake light. It don't work at all but the third brake light works fine all the turn signals , flasher and parking lights works fine. I had wired from third brake light to rear light and it will work but it affects the turn signal so what could be wrong with it? Brake switch has been replaced, is there another switch to separate these two the third and rear brake lights?
Thanks
2008 GT Mustang
1988 Thunderbird Turbo Coupe
1967 Blown Alcohol Mustang
1993 Ford F350 Dually Banks Turbo Powered Diesel
Check your email.
Edit. the email bounced. Might need to update your profile.
Trickie67
Oct 2005
New Mexico
I cant change the email because someone hacked into it a while back so u can send it to [email protected]
Thanks
2008 GT Mustang
Trickie67
Oct 2005
New Mexico
I got the email changed.
Thanks
2008 GT Mustang
Resent to new addy
Trickie67
Oct 2005
New Mexico
Don't see it?
2008 GT Mustang
The transition is in the MULTI FUNCTION SWITCH. It is used to cross over from signals to brake lights. Wiring for the Third light comes directly from the brake light switch, The T Bird uses both stop and signal filiments so they have to be Phased out to work correctly. Their is no seperate signal bulb in the COUPE. If you jump the third light the signals wont work correctly. Replace the multi function switch. And wire in a slave RELAY to protect it. Hope this helps
Trickie67
Oct 2005
New Mexico
Would the multi function switch be the where the light switch is?
Thanks
2008 GT Mustang
The switch controlls the cross over from blinkers to stoplights when turning. Hope this helps.
boosted chicken
Jan 2006
Odessa, Texas
Thanks
The turn signal switch is the multifunction switch.
