Brake Lighjt
B D Offline
When I accelerate from a stop or slow speeds, my brake light comes on in first and second gear. Not my yellow ABS light, but my Red brake light. Is this light only to show that your parking brake is on? My brakes feel fine. Could the rear end be twisting and pulling on the parking brake cable? Anybody else have this happen?
B D
87 TC 5-Speed, Remote mount K&N filter system,Steeda Shifter
88 Thunderbird Sport 5.0
91 Ranger
87 Turbocoupe 5-Speed, Remote mount K&N filter system,Steeda Shifter,New Heater Core,new clutch.
88 Turbocoupe "Mach 1 SE "
88 Thunderbird Sport 5.0 (Retired)
91 Ranger
oldone Offline
It it is also turned on by the sensor in the Brake Master Reservoir, ck your brake fluid its probably low.
oldone
88 Maroon TC 5 speed
K&N Filter
Gillis boost valve
oldone
K&N Filter
Gillis boost valve
220,000 Miles
oldone Offline
My bad. I meant Master Cylinder reservoir.
oldone
K&N Filter
Gillis boost valve
oldone
K&N Filter
Gillis boost valve
220,000 Miles
Kev Offline
The light will also come on if your brake pads are badly worn. This allows the piston in the caliper to extent more making the fluid level drop a little (or something like that)
Kev
1988 TC 5spd
bigred Offline
bump
[This message has been edited by bigred (edited 11-22-2002).]
1988 TC T-5 swap,New Head,Wiseco .030 pistons ,5.5 Crower rods ,balanced ,24x12x3 intercooler,T-3 .60
Ranger Roller Cam,New brown tops.
New 3"cat and 3"single SS exhaust
bigred Offline
Try checking switch on parking brake mine was loose and kept comming on every time i hit a bump in the road
3" cone filter(spectra)
,boost Set at 18 psi,No Knock sensor.
New 3"cat and 2.5 duals.
1967 F-100 Ranger short bed 352/2 barrel
1969 Pontiac LeMans
1988 E-350 Cargo van 351/C6
2000 Explorer 4.0 auto
roushracing6 Offline
Before I replaced my parking brake cables I had this occur when braking or hitting bumps. It was due to no tension on the parking brake pedal.
88 Tc 211,000 miles slowly rebuilding to stock. Silver with red leather interior loaded with all the toys. My second TC in 1988 bought one as my first new car purchase missed it ever since I sold it in 1991.
88 Tc 211,000 miles Silver with red leather interior loaded with all the toys. My second TC in 1988 bought one as my first new car purchase missed it ever since I sold it in 1991.T-bird died but not forgotten...
I am beting on P brake switch also. To verify the problem, pull the connector off the park brake switch, and let it hang, and see if the problem goes away. If it does, the switch is the problem.
Hybridbird Offline
Check your fluid level.Mine does the sma ehting when it is low.
B D Offline
It turned out to be the fluid level was low. The reservoir was discolored and I had not noticed that it was down. Thanks for the replys. I did not know that the light would come on if the fluid level was not right, so yall pointed me in the right direction.
Thanks
B D
91 Ranger
91 Ranger
