miamihawk
Feb 2002
Fredericksburg, Va
Does anyone have pics of there bypass valve install?
Dave
Fender Well KN Flter, 255 HiPressure Fuel Pump, Full 3" Exhaust DP to tip with no cat, Magnaflow Muffler
This is a picture of SteveX2's installation
SteveX82
Toms River, New Jersey
I'm so flattered [Image: smile.gif]
I'd like to point out that I have since reversed the direction of my BPV. I am now using the side port as the input end and the bottom port as the output end. After visually inspecting the insides of the BPV, I decided that using it in that direction would enable the valve to hold the most boost without leaking.
I have mine hooked up "reversed" from your pic (the way you have yours hooked up now... side in / end out), and it holds 21 psi no problem.
miamihawk
Feb 2002
Fredericksburg, Va
Jeff, Do you have a picture of yours?
Not a good close up pic, but my install looks almost the same as Steves... I just tapped into the IC tank several inches farther back (toward the firewall) than Steve did. My install was a bit tighter than Steves, as I still have functioning A/C.
