I needed to tap into my charge pipe for my BOV, it has two ports which gives a faster response preventing compressor surge. I was having a issue after
installing the FMIC running 23 lb's of boost while shifting. Now it will vent as soon as I let off the throttle a little. It's an adjustable BOV so I can really fine tune it and it's working great.
Couldn't find what I needed and didn't want to wait a week on shipping so all I did was find is a soft metal bolt and drilled a hole from the top through the bottom. I used 2 washers and a nut, cut a hole in the rubber coupling installed everything then added a small hose. Five minutes and it was done.
[img]
[/img]
[img]
![[Image: P1060327_zps8ddzf8ix.jpg]](https://i273.photobucket.com/albums/jj208/Racingjake/P1060327_zps8ddzf8ix.jpg)
