347BIRD
May 2019
ST CHARLES, MO
sorry if this is not a good question but can you put a bov on a stock turbo setup? I have an 88 tbird basically all stock and I want the noise a bov makes..... any help?
1988 Blk T-Bird, 5-spd, Raven int, 3G Alt, K&N conical, Boost controller, ported E6, ported and polished IHI @ 16 psi, 03 Cobra wheels, 255/40/17, 275/40/17, SN95 BBK lowering springs, SN95 Koni struts and shocks, Maximum Motorsports C/C plates, SN95 BMR tubular A-arms, Aluminum driveshaft, LED's, 255 LPH
Yes, I used a Stinger BOV and Tee coupling between the throttle body and intercooler.
Kuch
Sep 2016
Manlius, NY USA
Just like Jake, I did the same thing on my 88TC. I did trim the T coupling a little to fit better between the intercooler and the throttle body though. I have the BOV facing the front and it sits right near the oil fill cap. I used the dual piston style for now as I still have a VAM installed. Here's the link https://www.stinger-performance.com/stor...off-valves , he also sells the T coupling as well.
347BIRD
May 2019
ST CHARLES, MO
02-26-2020, 01:21 PM
(This post was last modified: 02-26-2020, 01:30 PM by 347BIRD.)
AWESOME THANK YOU!!! Im excited about blowing some tax return money LOL !!
Also would I want a double or single piston?? whats the diff?
Kuch
Sep 2016
Manlius, NY USA
Stinger says that the double piston one is better for a car with a VAM, if you still have the VAM installed. Many run an aftermarket engine control computer like a PIMPxS, also sold by Stinger that will get rid of the VAM and make more power as it is a restriction as you move up in power. For now, I still have the VAM installed but have a PIMPxS and bigger injectors to install this summer so I used the double piston one and it works great. Shannon who runs Stinger Performance is a great guy and has a great website with lots of info on it as well.
