Boost/Vacuum Guage
Gregg Offline
Been searching the archives, but can't get any part numbers...what boost/vacuum guages is everyone running?
And although I know it's controversial, what about A/F Guages?
1987 TC 5 Speed
K&N Cone mounted on the VAM, Disconnectd BCS, Ric Gillis Valve
[This message has been edited by Gregg (edited 07-03-2002).]
Gregg
Autometer 2164, goes to 30 psi on the boost side
Gregg Offline
Autometer 2614 Maybe?
Couldn't find a 2164 boost/vac gauge
1987 TC 5 Speed
Gregg
Gregg, your right, it 2614
KMcGrathNJ Offline
Autometer
Kevin
88 TC T5;White/Red; All options exept Leather; Front Mounted K&N cone filter; 140 Speedo; Superchip; Gillis Boost Valve; Custom vac/boost-volt-temp gauge cluster in console Ground Effects; Spoiler; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors; Infinity 5 1/4 component in rear deck;
Rockford 10" sub; (2) Alpine amps
Near Future -Paint
rv23tc Offline
i have an autometer boost/vac gauge it's 2-5/8 liquid filled it's for sale if interested let me know.
mods: 260 armstrong xp pump,430gears,,boost controller,FPR,9mm motorsport wires,K&N filter
GaryS#2 Offline
Whats so controversial?
Mine has told me a few times what's going on.
Once when I changed turbo's and used an 02 sensor that was buggered it went full rich.
Another couple times when I blew my IC off it went radical and favoured the lean side.
Mine has paid for itself .
Autometer # 5775 Phantom series
Grocery Getter/Rice Cooker.
My A/F gauge is a Cyberdyne, don't remember the model #. I'd rather have it than not have it.
Wags88TC Offline
Like Gary said.... 60 bucks or so is well worth the money! But if money is no object, a "wide range" meter at around $300 would be better(if that's the contraversial part).
Steve Wagner
Nato member
88TC, 5 speed, StageII Star clutch w/ StageIII pressure plate,lightened flywheel, K&N in fender, gillis valve, 255lph Walbro, Kirban adj.FPR,Bypass valve, 3" exhaust from turbo to tip (high flow cat/ Dynomax Superflo muffler), A-pillar gauges(A/F & Boost), 16" Prime 5 spoke wheels(245/50VR16 Yokos'). Workin' on the front mount IC and some exterior mods
Steve Wagner
Nato member
84 SVO
Steve, A wide range is where I want to go next. seems to be a must have for some of the after market engine management systems.
