I am able to get a spike of 7 psi in nutral with a stock 2.3 IHI TC 5 speed the only mods are: High-flow exhaust, K&N cone filter & a gillis valve set to 18 psi. I have had this set up for a long time and have not changed a thing!!! Now out of the blue I can get 7 psi in nutral, all most no lag in first (spins toyo's very easy!!!) If I hold the brake in first give her gas and let it roll a bit. I can easily build 18 psi and not have the tires spin, when I let the brakes go she allmost lifts the front wheels!!!
It seems to good to be true! Is she going to pop a turbo soon?
88 TC + a killer driver= one bird that can't be stoped!
2.5 in. side pipe exhaust with no muffler, K&N cone filter, Gillis set to 18 PSI...= the loudest TC knowen to man!It is time to build the Bitch of all 2.3's!!!!!!!
1988 Turbo Coupe
2.5" Stainless exhaust. Duals with flowmasters.
House of Kolor paint by: Glen Gordon
ROH Wheels
Lowered
Front Mount IC
Turbo Smart BOV
Gillis Boost valve
K&N
sounds like your doing something right
It's cool, but it can't be a good thing!
1988 Turbo Coupe
ROH Wheels
Lowered
Front Mount IC
Turbo Smart BOV
Gillis Boost valve
K&N
BJL
Williamstown, New Jersey
when that happened to me two days later the car was smokingm, water was in the oil, and i had ablown head gasket, hate to say that but that what happend to me,
three head gaslets, three clutchs, one motor, two turbos in only 25,000 miles!
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass.
http://crazydriver358.5u.com
Brian Larkin
88TC 330,000 miles
Slightly Modified
Glenn 88TC
Lebanon, PA
Do you still run a cat? it might be clogged. Did you mention on TF that you are having tranny/clutch problems?
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full sized, 60mm throttle body, 42lb. injectors, MSD 6al, MSD Launch Control, K&N filter, Walboro 255 pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Tiny Avenger bleed valve, Weld Draglites with M/T ET Street 26x11.5/15
Upgrades coming very soon: Hallman boost controller, rebuilt trac-loc, S&R Racing driveshaft loop, big roller cam, SDS Injection
NO TC and NO headaches.
ya I'm having clutch problems and there is no coolant in the oil or oil in the coolant.
1988 Turbo Coupe
ROH Wheels
Lowered
Front Mount IC
Turbo Smart BOV
Gillis Boost valve
K&N
