Boost makes less power?! blown gaskets?
k98311 Offline
So i was boosting around and i boosted first gear to 10 psi then when i out it in second and started boosting nothing happened! it pumps it gets all the way up to the intake but when i boost it makes less power could barley make it home but if dont boost at all its fine. the turbo will just boost away but nothing happens.
blown head gasket? i pulled the hose to the wga and it boosts past 10 psi, that sould happen right?
Scott Mabe Offline
Is there any other notable difference, idle quality, free rev characteristics?
1987 Turbo Coupe
1990 F-250HD 460ci
Most likely a boost leak. Remove and thoroughly check the two intercooler hoses completely. Squeeze them and see if any cracks open up. Be sure to get them correctly installed and clamped tightened. Does your car still have the IC bracket on the front. Without the bracket, the IC can pull out of the hoses.
k98311 Offline
no if the car doesnt boost it runs fine and drives fine. will upload pics of my fmic on my 86 and check the couplers.
k98311 Offline
could a gasket on the intake blow and do this? where does the stock boost gauge get its readings from?
Scott Mabe Offline
You could be losing fuel pressure. Without boost you have enough fuel, under boost your going lean, engine starving for fuel. I'd check the vacuum line going to the fpr. And then maybe your fuel pressure if everything looks good.
1987 Turbo Coupe
1990 F-250HD 460ci
k98311 Offline
So the vaccum line to the fpr look fine but should i replace the metal tubing in between the fpr and the intake?
How do i go about testing the fuel pressure?
k98311 Offline
The work looks terrible but it gets the job done! no boost leaks in the intercooler set up
Attached Files Image(s)
RDOG Offline
Your boost leak is that blow off valve. Under load its opening. Put in a higher load spring or stretch the spring thats in there. I have always disliked blow off valves. Turbo cars with VAM hate them. I would run a forge bypass valve instead, but if your mind is set on a BOV get the dual piston from Stinger.
You can check what I am saying by removing the blow off valve and plugging the hose. See if the car runs better. If so, its that BOV.
^^^^^ +1 with Chip.
