TheRedhead
Feb 2002
Willow Grove, PA USA
Hey guys .. it's been awhile since I've been on but I got a ? and came to the masters [Image: smile.gif]
One more time can y'all explain how to disconnect the boost limiter? I'm guessing that's what it is, it's hitting something and spitting and sputtering. Thanks
If you are getting sputtering at higher boost now, diconnecting the BCS (boost control solenoid) will not make it better. you have some other kind of problem like loose iC hoses, vacuum hose or maybe a fuel or ignition problem. Check all your hoses first, and if the problem still exists, then pull the codes. Get back to us with the codes and a little more information on the running problem (when dies it do it when doesn't it do it, more on what it is actually doing)
[This message has been edited by Pete D (edited 02-24-2002).]
