boost leak checker????
ianbfromct Offline
No i dont have a great idea for a boost leak detector. I was curious if anyone had any ideas to check for boost leaks under a load at higher rpm?
88 5 speed TC
86 XR7 5spd Offline
normally you pull the hose off the TB and plug it
then pull the hose off the turbo comp outlet and apply pressurized air there
you can then test your entire IC plumbing
under load, running ?
if yu have an A/T car, yu can have someone listening under the hood while you brake-tork it ?
David T
2.5" exhaust w/ cherry bomb
Pete D3 Offline
Check this article:
http://natomessageboard.com/cgi-bin/ulti...020#000001
x
