Boost controller set up
k98311 Offline
Alright so i have a manual boost controller im going to install and had a couple questions. (i plan on only running 10 pounds aka wastegate pressure until i get supportive mods on) How do i set it up? my bleed valve came with a T peice and the bleed valve and plenty of line. do i leave the factory Vam (thing that makes it push more pounds from the factory) plugged in? what about its lines? i noticed from the wastegate line (line C) goes to the turbo where there is already a T peacie that connects to aanother line (line A) that goes to what i think is the VAM. and from this there is another line (Line C) going to the intake. heres some labled pics
Attached Files Image(s)
Dan S Offline
http://turbotbird.com/techinfo/GillisVal...sValve.htm
Start here and :read: the instructions, it's well written. Also, that's not the VAM, it's the Boost Control Solenoid. The VAM is the box like piece in the air intake hose between the air cleaner and the turbo. If you purchased a Gillis valve, did the install instructions come with it?
Dan S
1972 Ford F-100 SWB Styleside
2015 BMW 435i Hardtop ConvertibleĀ
2022 Escape Titanium Elite
Sean Offline
I set mine up like this.....it's kinda weird though, getting 17psi of boost under partial throttle.....makes me wonder what kind of boost is building pre-TB.....
1988 Thunderbird Turbo Coupe
160 amp 3G and upgraded charge/power supply cables.
k98311 Offline
no instructions came with because its second hand from a buddy.
so let me get this straight you PLUG the place where the T peaice was and cap the inlet of the BCS and not the outlet and then i get the rest
k98311 Offline
wait never mind i get it now
k98311 Offline
Hey guys im back and i need help i set it up right but when i have the boost controller on the lowest setting it just keeps climbing with no limit. but if i turn it just a couple clicks open i only get 10 psi. before this couple click point it just climbs
k98311 Offline
is it possible my unit is defective?
k98311 Offline
bump. i need some help still. Sad
zip Offline
Going by your pictures
You would connect 'Line C Start' to the top port on the boost valve. This is the line that goes to the wastegate. The bottom port on the boost valve needs to be connected to the vacuum tree or to your turbos compressor housing. You can do this by removing the fitting where 'Line A ends' and replacing it with a new fitting. The vacuum tree is fine and easier. You will need to cap any of the ports that no longer have hoses on them. Also just to make sure your clear on this, the valve increases boost as you screw it in and decreases when unscrewing it.
Matt
