Boost control Bypass? HELP
TgrPrl Offline
Hi there - I think my mechanic is onto something, but we need your help still.
He bypassed the boost control selenoid (and hooked the vaccume lines together) that I replaced and the car builds the 15 lbs of boost it is supposed to.
#1 - what controls the boost control selenoid? (the one located next to the passenger side front fender behind and under the air box)
#2 - can you leave the booost control selenoid bypassed ?
Any advise you have is greatly appreciated!
1988 Black TC - Stock for now.
155K on the odometer.
#1 - The PCM
#2 Yes..... this isnt a "new" trick. This has been around for many years. Ususally connecting the hoses together gives 17 to 18 psi. A Butt splice between the hoses restricts air flow and gives typically 15 or so psi. Be aware the factory boost gauges are often inaccurate.
xcrunnerbd Offline
The computer controls the BCS, thru the plug. But only when the fuel switch is on premium. When it is on reg. BCS does nothing.
Yes, the BCS can remain bypassed. Do you have power running to the BCS? Perhaps now is the time for the Gillis Smile
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
TgrPrl Offline
Thanks so much! He did confirm the power is going to the BCS. He couldn't believe the difference in the power! I will oder the Gillis today! Going to pick up the car during lunch. Can't frigging wait! Next question. Which Gillis do you all recommend for a stock set-up? Is the basic one good?
Yippeeeee... I am stoked.
gadgetolds Offline
Yep, the basic one is the one you want..
TgrPrl Offline
I just pulled up my email from Ric Gillis -
The standard BoostValve kit for the TC is the one he recommended too!
TgrPrl Offline
This one, right?
Manual Boostvalve kit
Includes Boostvalve manual boost controller and all necessary parts and instructions to complete installation.
Yep!
TgrPrl Offline
So installing the Gillis is better than leaving the BCS out of the loop, right?
Can you explain why this is (just curious).
Thanks
Cerebral Offline
Because the gillis is adjustable, just unhooking the bcs gives you a set amount of boost. And then you can put it in your signature, and it makes you look cooler.
1987 Automatic TC- parts car
1987 5 Speed TC, K&N on Vam,Boost controller, T3, Bob's Log, Stinger 3 inch exhaust with Magnaflow, FMIC, Forge Dual Piston B.O.V., Ranger Roller, Esslinger Adjustable Pulley, Boport Drop in Valve Springs, Pyro Pete Clutch
