Bone stock track results
DAN2.3 Offline
Went to Napierville Dragway October 25th and did new personal record with my bone stock t-bird.
14.21 at 94mph with 1.91 60ft. I guess it's not to bad since it was done with a bog just before the finish line. I'll try to fix that before the week-end and if the weather's good,i'll try to beat that time.
Medium Budget Dan!
87 TC,stock long block with a237 cam,Stinger 3 inch exhaust and PIMP,svo T3,75# injectors,top mount intercooler with bov,3500 stall with c4,Hoosier slicks and skinnies.
tr_guy79 Offline
14.21 in the 1/4???
If that is BONE stock, people in hell are no longer thirsty...
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
Redbone Offline
Quote:Originally posted by tr_guy79:
14.21 in the 1/4???
Yea, that's kinda what I was thinking.
According to MotorTrend, a stock '87 5 speed was running low 16's.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
tr_guy79 Offline
The best I ever got out of mine stock was something like a 16.03, if I remember correctly.
My brainometer tells me you would need somewhere around 325hp at the crank and be a damn good driver to pull off a 14.21 in a TC
How does a "bone stock" 155HP Auto TC turn in over 2 seconds better than what the mags got out on a 190 HP, 1987 5 speed? Anxiously awaiting video, time slip and other reconciling factors.
DAN2.3 Offline
Hoosier and technic! Front and rear sway bar removed and power steering deleted!!!!
I'll also have a picture of the engine compartment as soon as i figure out how to post them.
Medium Budget Dan!
tr_guy79 Offline
I had technic once. They gave me a pill that got rid of it.
Dan, you have to understand our skepticism. You are claiming you are about 3 sec better than stock due to some slicks and an STD. I'd love to know how you did it. Even with my mods (see sig) I am not sure I could pull off that time. I am not even sure your fuel pump could keep up...
DAN2.3 Offline
Fuel pump will be the first modification that i will do,also i bought a front mount ic like a week ago.Planning on changing tb to 94-95 5.0L and port the intake.The only thing i'm not sure is if it will be blow thrue or normal.I picked up a holset hx35,but i also have a t3.I also need to switch to roller cam because this is holding me big time.
Medium Budget Dan!
DAN2.3 Offline
See time slip in track lounge
Medium Budget Dan!
DAN2.3 Offline
See video on youtube under 1987 stock Thunderbird Turbo Coupe.
Medium Budget Dan!
