bogging issue with 86 TC
RDOG Offline
I have been having this bogging issue. When I rev it and hold the rev above 4500 rpm. The car bogs and revs in a up and and down rpm surge. Its as if timing is being retarded. This even happens when I disconnect knock sensor. It reminds me of what my 2004 Mustang does when the car is parked and you rev it to high.
I installed a kirban adj fuel pressure set at 40 with vaccum line hooked up, walbro 255lph pump, and cleaned and flowed brown tops- the car still does it. I did notice that when I am holding the rev at 4500rpm the fuel pressure gauge jumps to 51 and surges up and down from 43 to 51. What could be causing this?
I did replace on HLA because it would tick real loud and eventual fill. Could collapsing HLA's cause this.
Kev Offline
Base fuel pressure should be set with the vacuum UNHOOKED. I don't know if that was a typo or not, so I'm just saying.
Kev
1988 TC 5spd
RDOG Offline
Yeh sometimes I set it with line off and then turn it up until I can hear the cars sweet spot. Crewed but effectiveSmile
Fixed!! Stinkin Fuel filter. It's funny how you look at the big$$ issues first before the easy cheesey stuff. LOL!! Fuel filter $11.95 at Autozoo. Problem solved.
grey88smokin Offline
[b] Base fuel pressure should be set with the vacuum UNHOOKED. I don't know if that was a typo or not, so I'm just saying.
Fixed!! Stinkin Fuel filter. It's funny how you look at the big$$ issues first before the easy cheesey stuff. LOL!! Fuel filter $11.95 at Autozoo. Problem solved. [/b]
been there before myself with a bad fuel filter and tank. Pulled the filter and saw how obvious the problem I had been chasing for months had been.
84 SVO 1C
08 MKZ
Dave8338 Offline
The same way I set timing on everything BUT the TC.
'86 TC: Granatelli adjustible clutch kit, Energy Suspensions, they own me, New KYB's, NOS heater core in the back seat, Chuck Warren Motor Mounts, Wallbro 255, Kirban FPR, New aluminum dual core. The Goal...all I need is the TIME!!
