body moulding
Nsw Offline
hi, i was wondering if anyone on here could tell me what the propper way to install and remove the body moulding is ie: the black plastic strips that run along the body with "turbocoupe" lettering
thanks: Joe
Welcome,
I use piano wire and "saw" them off. Best to have some help on the long pieces to keep them straight.
Do a search on "bodyside molding", this has been discussed before. I think there is a two sided tape for putting them back on.
Keith Nubel Offline
I used a heat gun (not a torch)to heat the mouldings, start at one corner and peel it back. Keep heating as you go and apply the heat to the back side. One thing Ford did right was the adhesive on the back of those things.
85.5 TC 5 speed, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount Motorsport intercooler & sport grille, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo,Motorsport lowering springs, under restoration
1985 TC
oldraven Offline
Piano wire? That's damn genius. I assume guitar strings work just as good. It's too late now, because I bent mine all to hell peeling them back, but the tecnique is stored in the files for next time. [Image: wink.gif]
I'd like to think my life has a soundtrack, and it sounds just like the white album.
1987 Turbo Coupe, 5-spd. Candy Apple Red w/ Charcoal Smoke Accents, k&n drop in, 2.5" duals. Stirring from her winter slumber.
http://www.cardomain.com/id/oldraven
http://www.cardomain.com/id/doasa
http://www.cardomain.com/id/jeepishltd
CAW!!
