blue smoke
V6TBird87 Offline
well, no oil on the plugs, so i know the smoke isnt making it to the combustion chambers, so that leads me to believe the turbo is blowing oil
the car sat for a few years, while being occasionally started and moved, would just driving it around, allowing the seals to possibly reseat cure the smoke? any input?
www.foxthunderbirds.fast-go.com
www.dodge600se.fast-go.com
aka Tbird232ci
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
How much blue smoke is it blowing, and under what conditions.... startup only, idle, cruise, WOT, closed throttle decel,or all of the above. If the amt. of smoke isnt excessive plugs will look normal..... they burn off deposits by design unless overwhelmed by tons of oil, fuel.
If smoke occurs mostly just after startup and on closed throttle decel, most likely cause is bad valve stem seals / worn valve guides.
V6TBird87 Offline
the smoke starts when the car warms up, its usually enough just to cause a haze around the car, when RPMs increase, along with oil pressure, the smoke increases, and when under boost, it increases more so
its a pretty good amount of smoke, it would be enough to make people roll their windows up at an intersection
aka Tbird232ci
2018 Mustang GT
aka Tbird232ci
