hi guys i was wondering if there is any info on blow off valves as in witch are better for an 88 TC and price ranges. thanks
natmac3
Mar 2002
Aberdeen, MD
I would say first, try the search option for "BOV" and "BPV" and see what you can find. Check here and at
ubb.turboford.org
On a more specific note, the BOV's BPV's best suited for our engines are the ones that can handle 15+ psi. The high pressure Bosch ones should be okay. The DSM Gen. 1 valves will work nicely ( I am going with this type, and can help you out with a simple mod to get it to hold more boost ).
The Denso valve that came sotck on the Probe's could work well. Most, if not all of these, will work best with a front-mount intercooler, but if you're thinking about getting a good BPV/BOV, you should probably already be looking for a better IC...
The lower pressure Bosch unit can be found on most junkyard Saabs, you might even find a worthwile valve on some turbo Volvo's...
The DSM Gen 1 can be found on early turbo Eclipse's and Talon's...
The Probe, on turbo Ford Probe's...
You should be able to find more info. simply by searching on the two boards, but if for some reason you come up short, le me know, and I'll be happy to help if I can...
I'm a turboholic and I'll keep comin' back...
Thanx for lettin' me share.
1987tc
i have been looking into buying a HKS SSQV blow off valve i have been told that this is the only valve that will proporly work for a TC becase it is a pull time any coments?
thanks for the help on finding info.
Grant
Jul 2002
Thomasville, GA
Do a search for "bailey" on turboford.org. Search the general techboard, off-topic, and archives (you'll see the drop-down menu on what forums to search). Good info on BOVs that work well on air-metered cars.
83 TC : full 3" exhaust, 17" 93 cobra wheels, many mods awaiting install once the engine's back in
[This message has been edited by Grant (edited 02-16-2003).]
Red_LX
Dec 2002
Morgantown, WV
Garrett Hunt
Moderator, 2.3L & Turbos Forum @ forums.stangnet.com
'87 Thunderbird Turbo Coupe
Windage tray, crank scraper, P&P head, RR, ARP head studs, P&P intakes, 60mm TB, Accel AFPR, Bob's log, T3, big FMIC, blow-thru VAM, Forge BOV, 3" exhaust, UPR shifter, gauges, etc.
My Turbo Coupe
I use the first gen DSM valve, mounted on the stock IC. It works very well.
88 TC + a killer driver= one bird that can't be stoped!
2.5 in. side pipe exhaust with no muffler, K&N cone filter, Gillis set to 18 PSI, 1gDSM BOV...= the loudest TC knowen to man!It is time to build the Bitch of all 2.3's!!!!!!!
1988 Turbo Coupe
2.5" Stainless exhaust. Duals with flowmasters.
House of Kolor paint by: Glen Gordon
ROH Wheels
Lowered
Front Mount IC
Turbo Smart BOV
Gillis Boost valve
K&N
