mytbird
Aug 2009
Queenstown, Maryland (Eastern Shore)
The last time I drove the Goldbird, I noticed the Ride control light started blinking after I rounded a curve - blinks 3 times a few seconds apart, then no light for about 10 seconds, repeats the series.
Can anyone tell me what's up?
(Also, the ride control light on Blackbird stays lit all the time now - since we're on the topic, any input here is appreciated too - seems like the birds are collaborating!)
Thanks, Karen
tr_guy79
Jan 2004
SE PA (DELCO), USA
Goldbird -> Is blinking a code... 3 flashes is a fault in RF actuator/circuit. The TC FAQ at the top of your screen will tell you how to troubleshoot and possibly fix it..
Blackbird -> Sounds like the switch is set to FIRM, or the switch/wiring is bad, and the PRC computer thinks that it is set to FIRM
-Shane
mytbird
Aug 2009
Thanks Shane -
I should remember to look in the FAQs - on Blackbird, the car feels like its in firm ride, and the switch seems a little funny, so maybe it's just the switch.
I don't work on these issues in the cars (I'm better at replacing interior parts and simple to change out things) - so I'll need to find a Ford dealer or my local shop to give these things a go. Think I could install a new switch, so will have to give it a go.
Do you know if I will do any harm to the cars driving them with these issues in the short term?
Thanks, Karen
tr_guy79
Jan 2004
SE PA (DELCO), USA
Karen,
It wont do any harm at all. My '87 had a blinking FIRM light for the first 8 or so years that I owned it... You may notice the car rides weird though, as some shocks may be on firm and others on soft
Put the switch in the firm location untill you get it fixed, it doesn't blink in the firm position. The blinking drives me crazy, lol.
tr_guy79
Jan 2004
SE PA (DELCO), USA
Depending on the problem, it may still blink in the FIRM position. There is actually a signal sent back to the PRC brain to tell it if the actuators were successful in switching to the selected mode. It is simply a voltage signal (ground I think). Depending on the failure problem, the PRC may still blink in the firm mode.
-Shane
PRC feedback is a switch in the activator. Open in firm / closed in soft (or the other way around.... cant remember right now). If the activator is bad, they can be easily taken apart and cleaned out / repaired. I think there is info on that somewhere around here. One quick test is to feel the activator while someone switches from auto to firm and back and see if you can feel a "thunk" whenever it switches.
thumper
Jun 2001
Dexter, MO
The only failures I've suffered on my TCs relating to the PRC was failure of the front struts. Two of my TCs would not switch back and forth between soft/firm. The activators would work off of the struts, but when installed they would not operate... i.e. the valving mechanism in the struts gave out. I'd have the light blinking three times. One of these was the white car: when it did (sometimes) switch to firm, it was like riding with no fluid in the struts at all (BOUNCY). I took them off and replaced with Monroe Sensatracs.
GOOD LUCK!
A.K.A. Corey Bennett
