Blinker and Reverse light fuse
Mark'87TC Offline
my blinker and reverse light fuse keeps blowing, does anyone know where shorts would typically be for this problem?
First, pull all the bulbs and see if the fuse still blows. Could be a bad bulb, or short in the socket. Inspect sockets carefully. If sockets are OK, and fuse still blows with bulbs, check connectors on multifunction switch for melted terminals shorting. See if fuse still blows with connector off MF switch. Good luck.... these kinds of things are a PITA to track down.
Resurectedbird Offline
also, check your blinker fluid, it may be empty.
just kidding
Sorry, had to say it before someone else did.
Currently birdless, but will get another someday!
