Cleven
Nov 2021
Arkansas
12-12-2021, 09:00 PM
(This post was last modified: 12-12-2021, 11:57 PM by Cleven.)
With vam can you use the bleeder style boost controller? I know these cars are very sensitive when it comes to vacuum.
Bleeder style is not the way to go. You want a pressure relief (ball and spring) type of valve, like the Gillis valve. Pressure refief valves build boost more quickly that bleeder type valves.
Cleven
Nov 2021
Arkansas
(12-13-2021, 03:44 PM)Jeff K Wrote: Bleeder style is not the way to go. You want a pressure relief (ball and spring) type of valve, like the Gillis valve. Pressure refief valves build boost more quickly that bleeder type valves.
I figured that on these cars. Appreciate it
