Black soot and too much heat
blackbird Offline
Hey ya'll Got some black soot that is coming out of my duals. It doesnt smell like oil or gas. Can my cat be plugged? If so, I can get it fixed easy and cheaply. All I need to do is knock the inters out, cusae the dont enforce emissions here. I also have a cooling prob. My main fan comes on in the KOEO and stays on through the whole test is that norm or is something wrong with the relays? It also doesnt come on when the engine is hot. The car is a '88 TC with a manual trans. If that helps any.
Im always showin' people the Bird when on the road or in the driveway. hehe
See the FAQ for test on the cooling system.
I doubt that the soot is the converter. Sounds like it's running rich. Check the fuel pressure. Did you run the KOER part of the test? What codes?
Nate K Offline
Possible the O2 sensor need replacing. A bad O2 will cause the engine to run rich.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
If the fan runs during the KOEO, the relay is good. Assuming the temp gauge is accurate, and you are actually running hot (a BIG assumption!!), I would suspect the ECT sensor is bad, or the coolant passage / little hose that goes into the bottom of the lower intake is plugged.
