abolt357
Feb 2002
Hot Springs, Virginia, USA
My wife's looking at me funny now. I spent a lot of time and a little money on this repair and I'm not seeing any light at the end of the tunnel! It's puffing black smoke intermittently and seems to be missing during the smoking. I'm getting codes 41 and 42.
Items changed: dist. cap & button, TFI, PIP, O2, FPR, TPS, intake gaskets, computer, PCV.
Stuff checked: fuel-39 PSI all the time, VAM voltage, TPS voltage, timing (10 deg), vacuum, vacuum leaks, cam timing, compression (150 PSI), battery, IC hoses, IAC clean, EGR clean, fuel injectors cleaned and flowed, CAT "cleaned out", fuel diagnostics.
I'm running plug wires with 5000 miles on them and NGK power-V's.
What am I missing? I've got to get her on the road again.
NATO member
88 TC
NATO member
88 TC (5 spd swap, 2-1/2" ATR duals, 3.73 LR, 255 Walbro, Adjustable FPR, Gillis)
88 Ranger XLT(2.3 naturally!)
01 Taurus 24V
FP at 39 psi all the time?? You mean it doesnt change if the vac hose is pulled off the fuel pressure reg. with the motor running? If that is the case, either the vac line is plugged, or the regulator is shot.
How did you check the VAM voltage? Did you check to be sure it increases linearly from ~.3 V to ~4.5 V, with no jumps, as the door is opened by hand with the key on, motor off?
abolt357
Feb 2002
Just checked the FP again. It is 39 PSI all the time except when the vac hose is pulled off, it goes to 44 PSI.
The VAM is smooth from .3 VDC to 4.5 VDC.
NATO member
88 TC
NATO member
01 Taurus 24V
abolt357
Feb 2002
Well, I put new Motorcraft wires and Autolite copper cores on today...this car is about to become a handgun target! The idle is rough, high idle is rough and it's smoking black like a tire fire! Any ideas?
NATO member
88 TC
NATO member
01 Taurus 24V
Have you pulled the codes?
abolt357
Feb 2002
41 and 42
NATO member
88 TC
NATO member
01 Taurus 24V
Chris Ruhl
May 2001
Oakley,M.I.,48649
It's the fuel pressure regulator! I have a fuel pressure gauge hooked up to my car and it was only running at 24 psi from the factory. It's flooding it's self causing it to smoke and miss. Your ignition won't burn that much gas at one time.
Chris, 39 and 44 are about what you want to see at idle and at idle with the reference line disconnected.
If you car is acutally running at 24, you have a problem. You should see at least 35.
abolt357
Feb 2002
Would a failing coil do this? Has anyone had a coil fail before?
NATO member
88 TC
NATO member
01 Taurus 24V
Turboy
Oct 2001
Roseville, CA USA
A bad coil could do this, but...Have you pulled the plugs and checked them yet? See if you have a couple that are wet - that might help to isolate the problem. If one or two are wet and you have spark there, suspect injectors. The fuel pressure does sound a little high - I think that the book calls for around 35 psi (vac line on) and 40 psi (vac line off). Let us know what you find - I've got an 82 Toyota that is doing the exact same thing (but, due to a long story, I can't get to it to fix it).
1988 TC 5 spd K & N, Bleeder. Next up - 3" downpipe to 2.5" duals
