Big Prob
Alaskanzeus Offline
Putting on some new ic hoses and found oil residue in the ic from the turbo inlet side. ok so whats my damage [Image: frown.gif]
Alaskanzeus Offline
Hold up this isnt oil this is very high carbon build up
Sounds like it's from all that clean filtered air, like what builds up in the IAC over time.
Try this: http://natomessageboard.com/Forum1/HTML/008952.html
Alaskanzeus Offline
Well that helped alot thanks again Pete. Not sure if thats the entire problem, found a very large chunk of carbon clogging the vaccuum T attached to the IC. Also alot of good size deposits inside. The IC is now hand polished, not Dan material but still looks a whole lot better than the 4 lairs of paint that was covering it. Sure it will run a whole lot cooler to.
