Keith Nubel
Liberty Township, OH
Who makes the best short throw shifter? I had a Hurst at one time and hated it. It was noisey and hard to adjust. Just looking for some opinions.
85.5 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler & sport grille, underdrive pulley, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo, under restoration
1985 TC
motormenace
Jun 2001
Timonium, MD
i think PRO 5.0 is still the best. never had a problem with mine.
86 turbo coupe (14.9),2 86 2R SVO's, 90 mustang GT, 69 mustang coupe
...so you have a V8...isn't that cute...
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
I have a Steeda Tri Ax. Works great!
Chuck W
Indpls, IN,USA
My vote goes for Pro 5.0 as well. It's a great product and Joe is a great guy!
83 TC Clone, 87 Ranger (soon to be 2.3T), 84 XR7, 80 XR7, 86 XR4 and 62 Mercury Monterey
Hybridbird
Aug 2001
Rockford IL
B&M Ripper,beat it all you want...bet you can't miss a 2-3 shift if you try.Billet base,stainless one piece handle,adjustable stops...and short!
"Finch....get the f*ck away from that fikas......that is a jizz-free fikas!"
Glenn 88TC
Lebanon, PA
Never missed a gear at the track with the stock shifter since I bought the car in 90. I can't see spending the money on one.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
tylerport
Freedom IN
I put in a Steeda Tri-Ax. It is very short and shifts great. It does allow a little more noise in than the Stock one though.
Jim Portteus
My Car
86 Turbo Coupe, LA3 w/ Intercooler and Larger VAM, Gillis Valve, 2 1/2" Downpipe to 2" Duals w/ 18" Glasspacks, 245/50R16's, 140MPH Speedo, A-pillar pod w/ Boost and A/F Ratio Gauges and Steeda Tri-Ax Shifter.
Jim Portteus
gtbird
Dec 2001
Hope, RI 02831
I've got a Steeda Tri-ax and I love it. No missed shifts, nice firm & crisp. As far as noise, yes it's a little noisier but that's because it doesn't have that big mushy rubber bushing. If you tend to drive around with your hand on the shifter it seems to transmit more noise than if you keep your hand off it.
