Best guads?
Harvs Offline
I need new guads, what are the "best" in your opinion? I was leaning towards the Konis
If you have to have the absolute best, and have deep pockets, I agree that Koni are probably the best, but the quads are of secondary importance to the suspension, and I personally would not spend big $$ on them. I am perfectly happy with my $12 each Monroes. If you use aftermarket control arms, the quads become completely unnecessary.
Harvs Offline
I dont know if you or anyones else had had this problem but, when i hit bumps the back end kicks out, not the tires, but the body, it really annoying, what could it be?
Chuck W Offline
Old, soft, squishy, feeble control arm bushings (uppers more so). Also a dead Quad, or shock might cause some odd things to happen as well...
83 TC Clone, 87 Ranger (soon to be 2.3T), 84 XR7, 80 XR7, 86 XR4 and 62 Mercury Monterey
Harvs Offline
Quote:Originally posted by Chuck W:
Old, soft, squishy, feeble control arm bushings (uppers more so). Also a dead [b]Quad, or shock might cause some odd things to happen as well...
[/B]
I have those 12 dolllar guads i just changed so its not those. And i put brand new PRC shocks on so it must be the control arm bushings. Do any old autoparts store have them?
natmac3 Offline
$88.00 for the rear-end rebuild kit from PST.
--n8
1987tc
Glenn 88TC Offline
Quads? I don't have no stinkin quads. I removed them 3 years ago.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
Chuck W Offline
Yeah, I have never run them either. They're a factory band-aid there to help dampen the the fact that Ford chose to use the largest rubber bushings known to man, and the slapper bars on the early cars were too noisy. If you get some better lower arms, or install poly...you'll be negating the need for them..
Glenn 88TC Offline
Good lowers, I guess that means HPM's. They are the only ones made for our cars anymore, aren't they? I know you can run a GM "A" body upper.
Chuck W Offline
Yeah Glenn..HPM is probably about it. I know that KB is going to be discontinuing the Tbird stuff..I just don't know when. If I wasn't elbow deep in this motor mount project and the IRS project for a buddy of mine, AND my own car projects, I'd look into it myself.
Anyway, I'm hyjacking the thread, so I'll stop [Image: biggrin.gif]
