RDOG
Jun 2001
Ontario. California U.S.A.
What is the best ball joint removal and press too that makes it simple and a one man job. I am looking for a tool that will allow me to do it with A arm still in the car.
HCOR
Jul 2009
FOREST HILL MD
OTC makes a nice set up,
only memories
Not B Anymore
Nokesville, VA, USA
I have this kit from Harbor Freight:
http://www.harborfreight.com/3-in-1-ball...38335.html
Using an Impact Wrench with it makes the job really fast. Plus it's good for the U-Joints, too.
Not B Anymore
Nokesville, VA, USA
No I lied... I have this one:
http://www.harborfreight.com/four-wheel-...-4065.html
But I only got this one because it was only $10 more and I can use it on a wider range of vehicles.
lonstar7
Jun 2009
Round Rock, TX
That's the one I bought too. It worked ok but be prepared to apply some force, a long handled ratchet or breaker bar will help.
Lonestar7
Not B Anymore
Nokesville, VA, USA
I've never tried it "manually". I've always used a pneumatic impact wrench. With the impact wrench I would guess the average time it has taken me to remove or install a ball joint is about 3 seconds.
lonstar7
Jun 2009
Round Rock, TX
Impact wrench? That would take all the fun (and busted knuckles) out of it!
Lonestar7
Good to know i was just at a harbor freight at lunch i should have read this post first...
-88 TC Black
-97 Pathfinder
