believe it or not....it's ready for the dyno
Glenn 88TC Offline
Special thanks to Pete D, Jeff K, Scott, and my friend Tom for all the help.
Miracles do happen! Turns out the valves weren't bent. I got lucky on that one. In the last three nights we battled timing problems, setting the valve lash, fuel pump problems and electrical problems. Finally it runs and is ready(I hope) for the dyno. It sounds very crisp and smooth. Just need a few small minor things done tomorrow night and then it will get loaded on the trailer for Fri. morning. It was honestly one of those moments when everything just came together and fell right in place. Even the worse problem(fuel pump shutting off) was handled fairly quickly.
Thanks to everyone(except Scott [Image: wink.gif] ) for the kind and encouraging words. I really shouldn't have vented like that on here.
Numbers won't be posted till Carlisle.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
SteveX82 Offline
Way to pull through it all, Glenn! It sure is good to have to have some helping hands and smiling faces in your corner sometimes.
Good luck at the dyno, and be sure to get us some dyno sheets (with plotted a/f!).
Carcrazyscott Offline
Fine, be that way. Give me my part back now. I need it so my car will run now.
-Scott Ressler
Glenn 88TC Offline
-Scott Ressler
I didn't need it anyway. Put the engine in first!!!
As soon as I bolt the header on, the engine will be dropped in.
-Scott Ressler
Glenn 88TC Offline
-Scott Ressler
Not sitting behind the keyboard you won't!!!
turbocoupes Offline
WAY TO GO!!! [Image: biggrin.gif] [Image: biggrin.gif] [Image: biggrin.gif] [Image: biggrin.gif] [Image: biggrin.gif]
Garry McVey "BIRDS OF A FEATHER" Birdoprey always in flight... TBird TC owners are usually wingin' it
83 86 87 87 87 87 88 TC 87 XR4ti
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Look at my post count to yours. I think I'm getting just a little more done in the garage than you.
-Scott
Glenn 88TC Offline
-Scott
It's not my fault you worked on that Merkur! [Image: tongue.gif] I know, that hurt!!!
Matt S Offline
Sweet!
The contest is back on!
Sold it Sad*
2 Guest(s)
