BCS and Map
rich Offline
Hi guys,
1. If I use a gillis valve, do I need to keep my bcs connected electrically for the ecu?
2. Is there a difference between the Map Sensor (with vacuum disconnected)in the N/A vs the BPS in the tbird? I have both available.
Thanks
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
Dan E Offline
If you use a Gillis you don't have to have the BCS plugged in for the EEC. However, if you unplug it you will throw a code on your scanner at KOEO.
Dan Eaves
[This message has been edited by Dan E (edited 12-16-2002).]
Dan Eaves
Quote:Originally posted by rich:
Hi guys,
You can remove the BCS entirely with no ill efects. You will get a code 81 during the KOEO test if it is removed, which you can just ignore, or, if you dont want to see the code 81, put a 100 ohm, 1 Watt resistor across the BCS electrical connector.
Sent yo an E mail on that one.
Thanks
rich Offline
Thanks !!
