Battery Voltage?
w60 Offline
The voltage across my battery with the car off is 13.3 VDC, running it's 13.9 VDC.
Shouldn't the running voltage be 2 or 3 volts higher than the off voltage?
http://www.mycoachonline.com
White 88 TC Auto Trans
White 04 Honda CR/V
Blue 74 Honda Trail 70
Here is a good post on that subject and a test is outlined in the last entry:
http://natomessageboard.com/ubbthreads.p...#Post86721
13.9 V at idle with headlights and blower on is OK, but if thats the volts with all accessories off and engine recently started, thats low unless ambient temps are close to 100 deg. At a cold start with a few accessories on, 14.2 to 14.4 is typical, with a few tenths of a volt more in real cold outside temps.
What is the voltage after the engine is warm, headlights on, blower on high, and engine at 2000 RPM? Thats the important number.
w60 Offline
13.9 is warm and nothing on but the radiator cooling fans.
White 04 Honda CR/V
If both fans are running 13.9V is ok. They draw big amps. I assume you have the stock 75A Mitzu alternator?
w60 Offline
yep…everything is stock.
Thanks
White 04 Honda CR/V
