Kuch
Sep 2016
Manlius, NY USA
I need to replace the negative cable on my 88 but I cannot see where it goes through the maze of wires to ground. Does anyone know where it grounds and roughly how long of a cable I need to replace it? Thanks
It doesnt matter..... Just ground the main heavy gauge to any bolt on the engine block. Be sure the connection is clean an tight..... that is way more important than where you ground it. Dont forget the small diameter (around 12 AWG) that goes from the neg cable end to the fender.
