Go Roush
Jun 2005
Carroll, Iowa, U.S.
Help me dont know whats causing it.. My battery is being drained if the car sits for more than 12hrs. Ive checked the obvoius with stereo stuff and lights but I just dont know. Any help would be greatly appreciated.
03 Ford F150 Supercrew
07 Suzuki Boulevard C50T
1983 Turbocoupe
deadbird
Apr 2003
Paw Paw, MI
Have you done anything to the car recently? Do you have a multi meter? Live by a harbor freight?
1987 5 sp.
- 4.6 2v swap.
Scott Mabe
Nov 2013
Virginia
You could try using a multi meter that will read amps, with ignition off take one fuse out at a time and put the leads where the fuse was. Several circuits will have some draw, the one with the highest draw should be what's draining your battery.
1987 Turbo Coupe
1990 F-250HD 460ci
Have yoiu checked the rear seat reading lights. They can get turned on and never noticed. Switch is on the very back of the console.
boosted chicken
Jan 2006
Odessa, Texas
Scott Mabe Wrote:You could try using a multi meter that will read amps, with ignition off take one fuse out at a time and put the leads where the fuse was. Several circuits will have some draw, the one with the highest draw should be what's draining your battery. You can do this with a test light as well. Anything more than a very dim light indicates too much current draw on that circuit.
Measure amp draw with the DMM on a DC AMPS range connected between the batt neg terminal and the neg batt cable. Pull fuses until you isolate the drain. If pulling fuses doesnt work disconnect the output lead of the alternator. If drain goes away, alt has a shorted diode. Also pull regulator plug off alt. If drain goes away, regulator is bad. Even with extra stereo equipment, key off drain should be under 50 mA.
Go Roush
Jun 2005
Carroll, Iowa, U.S.
I changed motor lately and having trouble since. I will do the amp testing at fuses and go from there
1983 Turbocoupe
Go Roush
Jun 2005
Carroll, Iowa, U.S.
Even more interesting I have power in my negative system, with the negative cable unhooked and test light hooked to negative terminal of battery I can hook the test light to anything and it lights up.
1983 Turbocoupe
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
alternator. unhook it, plug AND main power wire, and retest.
-J0N
Scott Mabe
Nov 2013
Virginia
Go Roush Wrote:Even more interesting I have power in my negative system, with the negative cable unhooked and test light hooked to negative terminal of battery I can hook the test light to anything and it lights up.
Having the test light hooked up as described is completing the circuit and should light up if there's any draw on your electrical system.
1987 Turbo Coupe
1990 F-250HD 460ci
